Using SET_ATTITUDE_TARGET to control quadcopter
I want to control the quadcopter from a companion computer using SET_ATTITUDE_TARGET.
If, for example, I want to move forward\backward, I set the pitch, which causes the copter to accelerate. If I want to estimate the acceleration, I need to know the mass (Which I know, since I have a scale on my table) and the thrust. Is there anyway to get the current thrust value?
This brings me to another question - what is the meaning of the thrust value in the SET_ATTITUDE_TARGET command? I understand that 0.5 maintains the altitude, but how is the range (0.5,1] interpreted to thrust in physical units?
Thanks!
None of the Mavlink messages appear to give thrust information back to the user, and looking at the Arducopter source code, there is nowhere that the mavlink_msg_set_attitude_target_encode() is used, so I have to deduce that getting thrust information at present is impossible.
Did you get anywhere with this?
