I have a relay , it is powered separately (5v) and accepts a 3.5V input. On the Pixhawk, I have a the signal pin connected to the right most signal pin or aux output (pin 50). I see the user parameters start at RC6, but the documentation indicates that I can also use RC5. Do I need to change something with the servo channels also?
I have solved this - . I think I understand the servoX remapping to -1 for GPIO for a particular Aux Output. I tried to set SERVO5 -1(GPIO) and that did not seem to support using output pin 50.
Resolution: I set Servo9_Function to - 1, and restarted the FC by unplugging from power. For whatever reason using CTRL-F/reboot pixhawk did not reset the servo mapping.
If I have it right for the pixhawk.
SERVO10-13 - should map to pin 51-55 of the aux_output.
SERVO1-8- maps to main pwm outputs
Map a RC#_option be a relay,
Assign a relay# and set the correct output pin for the relay#
Assign the correct servo# based on the assigned output pin.
