Using Mission Planner to simulate an aricraft to test an Antenna Tracker
I want to revive an Ardutracker that I mostly built several years ago. I am running an Arducopter simulation in Mission Planner, I have a 916 MHz SiK radio on the tracker, and a matching SiK radio on the laptop running Mission Planner. How do I get Mission Planner to send the simulated telemetry data from the computer to the tracker?
Is it possible?
Thanks!
Rusty
The same as you would do for a real aircraft, you set up mavlink forwarding in Mission Planner.
