Do I understand correctly I need modified firmware to run Dshot300? I’d like to use the latest master with Dshot300 if anyone can point me in the right direction.
Any time I try to run it, the motors twitch a lot. Dshot150 works no problems.
I am running dshot600 ok, but you do need DMA
I’m on a control zero, so I’m pretty sure it had DMA?
I would think so
More characters
You are running dshot600 on the latest master firmware?
Well from a couple of weeks ago. It’s possible something has changed
I have been using Dshot300 for quite a while with no issues
Weird, it must be something specific to my build. I’ve tried Dshot300 many times over the past 6 months and always get motor twitches.
Which flight controller? I found that my cube orange couldn’t do it, but my CUAV flight controllers can
Nevermind, I see you are using a MRO FC… I wouldn’t think that would have any issues
Yea I’ve confirmed the control zero should be fine with dshot
I’ve done some flight with control zero and pixracer pro using dshot 150/300 without issue… soon i will test dshot 600.
Not sure what I was doing wrong in the past, but it works just fine now.
