Both GPS modules are configured correctly and show 3D Fix. When GPS_AUTO_SWITCH is set to 2 (Blend), I get “PreArm: GPS_AUTO_SWITCH==2 but no blending”. GPS_BLEND_MASK is not a parameter and was not able to load from the 4.5.7 configuration file. Does anyone else have this issue or has a solution?
Using a SpeedyBee F405 V4 (speedybeef4v4). Same issue on 4.6.0.
