Hello, I have quadcopter frame. So I connect pixhawk 6c and upload Ardupilot firmware. I did initial calibration and extended tunings to the frame. After stabilize take off is ok. When I changed to Loiter and Alt hold when fly they also ok . But I try to take off loiter. Then drone try to flip and and waving. I set the IMU Offset also. Do you have solution for this. I have uploaded Log file, parameters and video.
Thank you for you reply I read your documentation before and did same as you mentioned. I did not follow all steps. But follow main steps. I never faced problem like this. Do you have any Idea why happen like that case. In this frame FC not in the middle. Its on the front base. I made IMU offset related to that.
