Unexpected Yaw Behavior in Copter Motor tailsitters with only having a lifting wing with no control surfaces configuration
ArduPilot Configuration
We are using:
  • Vehicle: ArduPlane
  • Firmware: 4.6.3
  • Firmware Hash: 3fc7011a
  • Configuration: Tailsitter VTOL
According to the ArduPlane documentation,
** CopterMotor tailsitters without them (ie. only have a lifting wing with no control surfaces) must always use their motors to provide control while in fixed wing flight modes. Setting Q_TAILSIT_ENABLE = 2 automatically does this.**
with this unexpected yaw behavior
Issue that we noticed during testing.
When the aircraft is in FBWB mode, we are observing a yaw-rate response even when there is no yaw RC input.
In other words, the aircraft appears to be generating yaw-rate commands or yaw motion without an intentional pilot yaw command.
We would like to understand whether this behavior is related to:
  • The tailsitter configuration
  • The motor tilt angle
  • The Q_TRIM_PITCH setting
  • The Q_TAILSIT_ANGLE setting
  • The lack of conventional control surfaces
  • The motor mixing/output configuration
  • Or another ArduPlane parameter/configuration issue.
Currently we are flying with Lua scripts during the takeoff. Yaw rates we are enabling, and during forward flight we are disabling the yaw rate. Attached here Lua scripts.
YAW_Zero.lua (3.9 KB)
During Qloiter, the scripts enable the required yaw-rate controller settings. During forward flight (FBWB), they disable or change those settings. With this drone flying stable, we don’t have any issue.
Let me know if there is any setting I have missed or configuration in this
ArduPlane tailsitter
to help someone diagnose this, post a log
Please find the attached log file links. FYR
Thank you
The log shows typical attitude control loss of a copter tailsitter at high fixed wing speeds…motors are saturating resulting in not only yaw but roll instability…logs suggest this occurs at airspeeds over 25m/s…only solution is NOT to fly at those high speeds, or add normal fixed wing control surfaces…
Hi @hurzburg .,
Thank you for reviewing the logs and for taking the time to share your insights. Yes, we initially flew at higher speeds, but we have since reduced the airspeed to 18 m/s. As I mentioned initially, now we are using the LUA script to make the YAW loop gain zero in fixed-wing mode. This is stable and good, but I just wanted to understand if it’s a confirmation error or the is any issue in the firmware.
Regarding the fixed-wing control surfaces, “CopterMotor tailsitters without them (ie. only have a lifting wing with no control surfaces)”
Reference link: Tailsitter Planes — Plane documentation
