Howdy,
So yesterday everything was working fine and I was able to properly upload the firmware using eclipse, but today it is giving me problems. When I make the firmware and it asks for me to connect the pixhawk it detects everything like normal, but once it reaches this part it freezes and doesn’t do anything.
I went ahead and looked at the bootlog, and it just has this:
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
PX4IO CRC OK
nothing else. When I connect the pixhawk with my computer it gives the proper start up sound, it then goes and flashes red and blue, and finally it stops at 2 yellow flashes, which indicate an arming error. I try to connect to mission planner using the NSH command line, and it get stuck on waiting for reboot, it finally gets to opened COM port, and it freezes there. It does nothing until I disconnect. When I try connecting to the Mavlink, it just states “trying to connect” and counts down. after the countdown is over, it states “No Hearthbeat packets Received”. Which is weird because my blue IO light indicates that the heartbeat loop is running.
After this
I went ahead and changed the Baum rate on my COM4 port, which was set to 9600, to 57600. Now when I attempt to connect I do not get the “no heartbeat packets received” instead I get this:
I little progress, but I’m not sure what to do.
When attempting to update the firmware with Qgroundcontrol I get this:
Plug your board into USB now. Press Ok when board is plugged in.
Board found:
Port: \.\COM4
Description: \.\COM4
Attemping to communicate with bootloader…
Error: Sync: Send Command: Get Command Response: Timeout waiting for bytes to be available
When attempting to connect to the NSH using Mission planner I get this:
Rebooting COM4 at 115200 via console
waiting for reboot opened com port
When attempting to connect using Mavlink I get:
trying to connect
Timeout in 25
sometimes I get “no heartbeat packets receives,” but for the most part I get
imgur.com/KYosoQi
When attempting to install firmware using Mission Planner:
ERROR: Unable to upload firmware
ERROR: No Response from board
Any ideas?
