Unable to set home position
I got an APM2.5, i loaded firmware 2.78.
Everything looks good except than i can’t set hom position on MP using flight plan.
When i click on “set home here” i get the message “not implemented yet”.
As a result, ive no home position on the map and i can’t write PN’s in the APM because a Home is needed.
Someone knows what to do ?
Arno
Home is normally set as the point where you get a GPS lock when the system powers up. Is your GPS working?
The OP is talking about setting home manually.
Sent from my Ainol Novo 7 Fire using Tapatalk
