Unable to Enable Pre-Arm Checks + Unstable Flight (Pixhawk 2.4.8)
Hi everyone,
I am encountering several issues with my hexacopter and need guidance on resolving them. Here are the details of my configuration and the problems I’m facing:
Drone Configuration:
Motors: ReadyToSky 920 KV BLDC Motors
Flight Controller: PIXHAWK 2.4.8 (ArduPilot Firmware)
ESCs: ReadyToSky 40A 2-4S ESC
Battery: Tattu 22.2V 6S 25C LiPo
Transmitter/Receiver: FlySky FS-i6 2.4G 6CH PPM with FS-iA6B Receiver
GPS Module: NEO-M8N GPS Module with Compass
Propellers: Orange HD 1045 (10x4.5) Carbon Nylon DJI
Frame: Self-manufactured, carbon fiber (700mm x 700mm x 250mm)
Issues:
  1. Disabled Pre-Arm Checks:
Gyroscope
Logging
XY/Position control
Z/Altitude control
Battery check
These pre-arm checks are currently disabled, and I am unable to re-enable them.
  1. Instability During Flight:
The drone is unstable, especially at low altitudes (~40 cm). not taked Flight more then 50 cm altitude
It eventually crashes during landing despite no apparent hardware damage.
  1. No Logs Available:
Since logging is disabled, I cannot provide flight logs for further analysis.
What I’ve Tried:
  1. Recalibrated the gyroscope, accelerometer, and compass.
  2. Verified all hardware connections (motors, ESCs, GPS, and battery).
  3. Attempted to enable the pre-arm checks through Mission Planner and qground control, but they remain disabled.
Request:
  1. How can I enable these pre-arm checks (gyro, logging, xy/position control, z/altitude control, and battery) on a Pixhawk 2.4.8 with ArduPilot firmware?
  2. Could the disabled pre-arm checks be causing the instability?
  3. Are there alternative diagnostic steps I can take without logs to troubleshoot the instability issue?
This is the link of video
Any advice or guidance would be greatly appreciated. Let me know if additional details are required!
Thank you in advance
You can solve all these issues by:
  1. Update to the latest arducopter 4.5.7 firmware
  2. Reset all parameters to their default values
  3. Use Correctly configure ArduPilot for your vehicles on your first attempt | MethodicConfigurator
Follow the sequence, do not skip steps unless they are explicitly marked as optional.
Hello sir I changed my Pixhawk 2.4.8 s firmware 4.4.4 in this firmware there are lots of error and internal compass is not showing
I changed firmware to 4.7.0 dev it flying stable
Which firmware should I use for my hexacopter and Quadcopter
You should use ArduCopter 4.6.0-beta4 or ArduCopter-4.6.0 once it is released.
When it will relise I am making a delevery drone and cleaning drone
It will be released once it is finished.
Hey my hexacopter is flying good but I disabled logging because it is not solving my memory card is new
Fmuv3 4.5.7
And I want use a 12 volt pump how I use please tell me
https://dl.flipkart.com/dl/dgk-heavy-duty-12v-dc-moter-pump-140-psi-battery-operated-auto-pressure-cut-off-diaphragm-water/p/itma86bd5c535b01?pid=WPMGPFG5A3HUR5HZ&cmpid=product.share.pp&_refId=PP.6f2cce21-e5f2-4427-9b5c-3147f2c816d8.WPMGPFG5A3HUR5HZ&_appId=CL
With that pump it will be on On or Off so use a Relay to switch it.
