It takes much longer to complete just one axis tune. Well, AutoTune never completes. It is flyable for about 8-11 minutes on defaults settings and a bit heavier than I would like. Normally it only needs about 3-4 minutes per axis. Is my frame too “soft”. Aggressiveness is @ .1 Any help/advice appreciated.
try to balance your copter then add a vibration damper under FC if already mounted a vibration damper ,check for hard wires or other parts to dont transfer vibration from body to FC, also check propeller balance
Awesome, thanks for taking a look. Its a V shape Octo, you only graphed 4 RC outputs? I believe I’m still tail heavy. I can move the battery forward for better CG. I do have some questionable props on for now. Some have a few chips, just trying to avoid damaging new props. Vibrations could be a few loose wires/cables…
After remounting the FC on Zeal, and moved CG forward with double battery straps and taping down any loose cables, I think it has improved the Vibrations. Thank You!
