I have two LUA scripts.
The first script starts and stops video recording using a Seagull #REC connected to AUX 3. It is controlled using a Herelink.
It uses the method
‘servo.set_output (function_number, PWM) ‘
The second script simply sets one colour on 7 WS2812 LEDs connected to AUX 2.
It uses the methods
set_num_LEDs( output_number , number_of_LEDs )
set_RGB( output_number , LED_number , r , g , b )
send()
Both scripts are quite simple and are attached.
Individually they both work.
But If I load both scripts only the LED script works, so somehow the LED script disables the Seagull script.
If anyone can help fixing this, it would be appreciated!!
I noticed some anomalies with the Cube Orange and LED scripting a few months ago and never got around to fully testing, but I noticed that sometimes my own LED script would work and sometimes it wouldn’t. It seemed to help to add a 750ms delay to the LED script before executing any LED commands after initial boot.
When I connect the SBUSo to a tester I can see the Video channel PWM change but when I connect I connect the AUX Video channel there is nothing. It almost seems as if the LED script disables the AUX channel?
@WickedShell
Hi. Is there any chance of looking at this as there seems to be some conflict between the LED methods and this servo method? ‘servo.set_output (function_number, PWM) .
The LED scripts block the servo scripts?
Peter
Your running into the PWM groups, move one or other on to aux 5 or 6.
The PWM groups for CubeOrange are aux 1-4 and aux 5 and 6. You can only do one type of PWM in each group. LEDs is one type and servo pwm another hence the conflict.
