Two motors (C and D) spin at the same time when motortest
Hi all,
I’am encoutering a problem with motor test, when I run motor C motor C and D tunrs together, and when I test motor D I have the same problem, motor D and C turns together.
I have tried to disconnect motor C I have the same problem if I try to test motor C motor D turn also, and I also try to disconnect motor D same effect.
I have this board http://www.holybro.com/manual/Holybro_KakuteF4_V2_mini_Manual.pdf
I flashed the board with aducopter_with_bl, for information I have used this board 5 times on other drones everything work!
I’ve triesd to calibrate ESC with ESC_CALIBRATION parameter to 3, but it’s doesn’t work I didn’t hear any sound, (for informtion I’ve never done ESC calibration with my other board)
My params (same has 5 other drones)
discuss.param (18.5 KB)
I just loaded up beta8 on a KakuteF4Mini and loaded your parameters - motor test works fine. I can only conclude that you have some hardware problem, e.g. a short between the motors or a problem with the ESCs
I used it for years, I think there is an issue with ESC calibration no longer setting the corect spooling or it is a hardware issue i never seen before I ended up returning the board. Note no issue when using DShot.
I going to do a video if i have the time. I was able to reproduce the issue. [MatekH743]
Yes so I think I have an issue with my board unfortunately
