Two Current Sensors, no option for BATT2 analog current pin
I am setting up a VTOL QUAD with Matek Wing 743, where I have a Matek current sensor for forward flight, and which works correctly, and 4 x 1 Speedybee ESC, which has a current sensor output. However, to set it up, Matek manual says that the secondary current sensor input is pin 7 and should be definied in the parameters as BATT2_CUR_PIN = 7. However, there is no such option in BATT2. I have enabled BATT2, but there are no options neither for current nor for voltage…
you need to restart the flight controller for the rest of the options to show once you set it to analog voltage/current.
I did that, many options appeared, but not BATT2_CUR_PIN:
Sorry I got it. There was a mistake with where BATT2_MONITOR was set to scripting.
I had it as analog current only, but it did not show CURR_PIN. Only when I changed BATT2_MONITOR to 4, analog current and voltage, then did the CURR_PIN appear… Thanks
