Two 4in1 ESC Current and Telemetry data simultaneously
Hi everyone,
How can I have the CURRENT and TELEMETRY data from TWO 4in1 ESCs (SpeedyBee BLS 60A) that are connected to a SpeedyBee F405 V4 Flight Controller for an Octocopter setup?
Start with a more capable Flight Controller. It has one Current input and only 4 outputs that are Bdshot capable (for motor RPM). You won’t find current on the telemetry data on many 4-in1’s and for sure not those.
Can’t imagine why a Speedybee FC would be used for that application. But I wouldn’t use one for a toy.
What are your suggestions for a not-expensive flight controller and ESC with current sensor and telemetry data for an octocopter setup?
I don’t know what “non-expensive” means to you, I consider functional capability.
Matek H743
What do you see there with regards to battery monitor inputs and Bdshot capability?
