Tuning the Harmonic Notch
ok, i am reading it now. it is still as clear as mud. it begins great explaining what buttons to press and what window to open. gives a sample of noise - good. then it gets confusing. ‘open it in the regular way in mission planner and graph the throttle value. From this identify an average hover throttle value’.
that is not very clear - better have a screenshot and a sample. as i have learning set to 2 - i can get it right away - my hover value is 0.393618, i have it in the settings.
then
  • Set INS_HNTCH_REF = hover_thrust to set the harmonic notch reference value
  • Set INS_HNTCH_FREQ = hover_freq to set the harmonic notch reference frequency
  • Set INS_HNTCH_BW = hover_freq / 2 to set the harmonic notch bandwidth
what are 2 last params supposed to be set to? it would be helpful, may be, to do a compelte reference sample using the screenshot in there, to identify what each actual value is and where exactly is supposed to come from.
say, here is the data from my fpv tilt - what should be used from it:
Pull requests on the wiki gratefully accepted :slight_smile:
You want to set INS_HNTCH_FREQ to one of the two peaks. My guess is that the motor peak is actually the second one so about 180Hz? Then set INS_HNTCH_BW to 90Hz (half of the frequency). Does that sound right based on your motor size?
If it does sound right then do the FFT again after you have configured the harmonic notch to see if you need a static notch on the lower peak.
so, i did set _ref to the hover value, flew it, battery out of juice now, i will do it later. i saw CTUN->N to get some fluctuations, mildly, from 80 to 88 and so on, but not too much. FFT of that log does not look very different from the first one.
Sounds like you haven’t set INS_HNTCH_FREQ if it’s tracking from 80Hz. The minimum of CTUN->N should be INS_HNTCH_FREQ
it is set to 80. i posted it above. it is now as:
|INS_HNTCH_ATT|30
|INS_HNTCH_BW|50
|INS_HNTCH_ENABLE|1|
|INS_HNTCH_FREQ|80
|INS_HNTCH_HMNCS|3
|INS_HNTCH_MODE|1
|INS_HNTCH_REF|0.39something
So I think you want to set it to 180 or so based on your FFT. How big is your copter?
The maths assumes that you are tracking motor rpm. If you are tracking something else then your notch will basically miss
that one is a 450mm. so, you say the
|INS_HNTCH_FREQ|180
and the
INS_HNTCH_BW|90 ?
i am not sure, those are 800kv motors with 10" props - isn`t it too high for a freq for this size?
anyway, if it is set now to 80hz - that correlates to the first hump. but second FFT did not show any differences - why?
Yeah sorry, that size of copter I agree the first peak is probably the motors. It’s more like 90Hz though than 80 I think. What does the post filter FFT look like? That will tell you how well it is working.
i posted both screenshots of FFT above - what do you mean?
i actually see the first one had gyro x max of 32, second one seems to show max of 24. dunno, i need to fly it again with a proper lipo, charged.
Set INS_LOG_BAT_OPT = 2 it shows the gyro values after the filter stage
Also in the wiki :wink:
it is set. i see it in the settings. ok, it is not set. :slight_smile: i was looking at the old file. will correct it now.
ok, will go outside to try again.
Those graphs are for post-filter? Ok so I suspect you are just missing the peak a little. Try 90.
You can see why the dynamic FFT is a good option - it figures this all out automatically.
You could also set ATT to 40
ok, new FFT is here, with a proper 5mah battery on - previous one was a light one.
it looks like spike is at 100hz and filter worked. so i see i need to set freq to 100hz, and att to 40.
Yes, looks right. Good stuff!
is that now a default that should be set to any configuration, ESC based or throttle based?
in all other models i have it set to 30 - is the advice now to set it to 40 everywhere?
@Leonardthall and I have agreed this should be the default. Increasing it will not cause any harm and will help on copters with more extreme noise. I set it to 100 on some of my copters :slight_smile:
With the filtering enabled and configured as described in my prior reply, I was able bring the PID tuning up significantly higher than I have ever been able to do in the past. I was never able to get rid of overshooting at high speed high acceleration before. Bring the PIDs up that high started stuttering and fluttering and bad things. Now I’m able to bring it up and tune that overshooting right out. The pitch P alone went up 67% and D almost 40% higher. It can descend through it’s own wake a lot faster and more stable now too.
Hi Andy, I tested your FW with safety cable (1 meter). With the default parameters I had only one ceiling rocket (with the safety cable stretched and zero gas did not drop in altitude). However, for the first time, autotune started on the roll axis (unfinished for low battery). If setting the parameters as indicated in this guide (using parameters for quads less than 5 ")
http://ardupilot.org/copter/docs/tuning-process-instructions.html!
I had several uncontrollable rockets, so I put it back to default.
I set the filter notches as you indicated.
I have this FFT setting:
FFT_ENABLE,1
FFT_FREQ_HOVER,80
FFT_MAXHZ,350
FFT_MINHZ,100
FFT_SAMPLE_MODE,0
FFT_SNR_REF,25
FFT_THR_REF,0.35
FFT_WINDOW_OLAP,0.5
FFT_WINDOW_SIZE,32
INS_HNTCH_ATT,15
INS_HNTCH_BW,20
INS_HNTCH_ENABLE,1
INS_HNTCH_FREQ,80
INS_HNTCH_HMNCS,3
INS_HNTCH_MODE,4
INS_HNTCH_REF,0.14
INS_LOG_BAT_CNT,1024
INS_LOG_BAT_LGCT,32
INS_LOG_BAT_LGIN,20
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
INS_NOTCH_ENABLE,0
Andy, why 4?
Thanks :slight_smile:
