Tuning the copter by applying FFT notch filter and second as throttle
Hi everyone,
I’ve been tuning my drone and wanted to get some advice to make sure I’m going in the right direction.
Setup details
  • Flight Controller: CUAV X7+
  • Frame MTOW: ~7 kg
  • Motors: T-Motor 7005 230KV
  • Props: 24 inch
  • Firmware: ArduCopter 4.6.2
Issue
Initially, I faced some tuning issues related to oscillations. I noticed noise peaks in the logs, so I applied notch filtering — first tried a regular notch, then configured FFT-based notch and throttle-based notch as static (fixed frequency).
After setting these up and re-tuning (auto-tune + manual refinement), the drone now performs very well — stable, responsive, and efficient.
However, I’d like to confirm if my setup is correct and best practice:
  1. Once tuning is complete and everything flies well, should I keep FFT enabled permanently or can I disable it and just keep static notches?
  2. Is there a recommended way to verify that my notch filter settings (center frequency, bandwidth, gain) are optimal?
I just want to make sure I’m not missing anything before finalizing this configuration.
Thanks in advance for your suggestions!
Set these parameters and do a simple hover flight for a minute or so:
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
INS_RAW_LOG_OPT,9
Please have a look on the hover flight with above values.
I don’t see that you changed any of those parameters in that log.
Please check this today I did hover test with above suggested param.
Disable the 2nd notch and delete the 3rd harmonic of the 1st notch and it looks OK.
I would replace the FFT notch with a Throttle referenced Notch and disable the 2nd notch:
After completing the Notch filter configuration disable Raw Logging as it will produce huge logs.
Initially I tried with throttle notch but the tuning was not happening and producing poor tuning. Then i moved with FFT tune where the results are positive. May I know is there any problem that FFT causing for long run.
If its configured well then it works well. I use this as a “clean-up” notch typically as well as ESC and static notches.
