Before diving into advanced tuning such as notch filtering, I thought it was worth going back to the beginning and going through the entire tuning guide to verify that nothing was out of whack.
I discovered that both MOT_PWM_MAX and MOT_PWM_MIN were “0”. Seems to me these should be “2000” and “1000” respectively. I’m using T-Motor Air 20A ESC’s - set to intermediate timing. The wiki said use “2000” and “1000” unless the ESC manual specifies a fixed range. I can see no such fixed range mentioned in the ESC’s manual.
Maybe being set to “0” - these parameters are defaulting to “2000” and “1000”.
Should I go ahead and set them to “2000” and “1000” respectively?
One more question…
The docs say rely on the motor test feature for setting “MOT_SPIN_ARM” and “MOT_SPIN_MIN”. Of course I tested the motors when assembling the copter - but I can’t see anything that says how to set these parameters.
My current setting are close to the defaults - “0.11” and “0.13” respectively. (defaults are “0.15” and “0.1”). Should I leave my current settings alone - or switch to the defaults?
Many thanks!
