Trying to keep a savage little drone in the air
Hi good day all please can someone help .
I’m trying to get a savage little drone to behave.
3115 motors 900kv, tri blades 10’ , Pixhawk 6s controller 40 amp speedys
I got it all set up and “working” taken it for a few flights to check it out in Stabilize mode
I am following AI to help tune it but I think AI is confused as I am
Takes off slow now, add little throttle and it rockets up pull throttle back and it falls like a rock
I’m close but still far away I’ve set everything I know how but I’m missing something please help
2025-12-29 17-52-27.bin (515.9 KB)
Thank you for any assistance
Kevin
AI is very bad at this, because it has no training data.
Use ArduPilot methodic configurator software instead. It is designed for this very purpose and is the fastest and simplest way to get the job done.
Follow it’s instructions and do not skip stuff unless it explicitly tells you that they are optional. It is already the shortest path, it’s just not possible to make it any sorter and still get a working vehicle.
Thank you so much , I have just watched the video on it … wow I have a lot to learn.
Thanks again
Hi
Thank you so much, I have just watched your video. I have a lot to learn
Thanks again
