Trying to build a indoor autnomous drone with 360 lidar
Hello Forum,
Thank you for reading. im currently building a small Drone based on the Pixhawk6c and a Jetson Nano Companion Computer and was wondering a way to stablize(and avoid Objects) it indoors in a non stationary way. After some research i bought a 360 Lidar for horizontal avoidance, wich is working fine.
So now im trying to figure a way to sabilize it indoors in the most inexpensive way. Would a optical flow sensor fit my needs ? - or in other words can i use a 360 lidar in FlowHold Mode? Or would u suggest a entirely diffrent aproach like a stereo Depth Camera (i thought about the Oak-d Lite)?
Or maybe the 360 Lidar will do the Job itself?
(keep in mind i only got a Jetson Nano Platform as boardcomputer)
i would appriciate any input. Thanks for taking the Time
Greetings
Hi, I used this small and cheap optical flow and it works quite well, even if it suffers from time to time if the ground is homogeneous. For the low cost I’d give it a try. Here are some indoor and out door attempts
https://it.aliexpress.com/item/33005508643.html?spm=a2g0o.productlist.main.87.2b3656152gRU0d&algo_pvid=7c00daf6-a5dd-4949-8052-30cc3487a258&algo_exp_id=7c00daf6-a5dd-4949-8052-30cc3487a258-43&pdp_npi=3%40dis!EUR!13.96!13.96!!!!!%402145265416835276170147748d0768!67054626233!sea!IT!0&curPageLogUid=RfR55CprVQYJ
