I have a Trex 450 flybarless heli with a F405 wing flight controller running Arducopter v4. The heli is flying really well almost hands off in Alt hold. On the logs the Pitch , Desired Pitch and roll, desired roll are offset is this something I should be worried about as the documentation suggest they should be tracking each other.
@ardisd if the actual values are not tracking the desired then it is most likely that your ATC_RAT_PIT_ILMI and ATC_RAT_RLL_ILMI are zero. These need to be 0.08. They allow the integrator to build which drives the actual values to follow the desired.
@ardisd Sorry for not getting back to you sooner. Looks like the Error code 4 for the barometer and Compass is indicating that they are Unhealthy. Not sure what the impact of that is on your system. However it seems to happen a lot through out your log and then is resolved in less than 1 second. You may want to recalibrate your compass to see if that helps the compass errors. Not sure of how to deal with the Barometer.
David,
When you calibrate the compass, are you clear of any metallic objects that could affect the calibration?
I’m not sure I can help you with this issue. You may want to post it on the Copter 4.0 thread, if that is the version you’re using. Or you could post on the hardware thread.
