Transmitting video from Jetson via SIYI HM30
Hi @siyi7
I am building a drone using HM30 as a data link system, the drone has Jetson as a companion computer that does AI tasks on the video before transmitting it to the ground via HM30.
My question is:
If I connected Jetson Nano to HM30 via LAN interface as follows: (Jetson Ethernet output > HM30 LAN input), will I be able to transmit the video through HM30?
Is this applicable? or the HM30 is only designed to transmit video coming from the camera?
If anyone is interested, it’s applicable. Basically the HM30 works with IP addresses, so If you figured it correctly you can stream whatever you like using its LAN port.
Extra tip, I was able to stream 2 videos using SIYI FPV cam hub by configuring IP addresses as well.
