Tracker-4.7.1 has been released and can be downloaded using Mission Planner, QGC or directly downloaded from firmware.ardupilot.org.
The list of changes vs 4.7.0 are in the ReleaseNotes and copied below.
- Board specific changes
- ARKV6S board added (@dakejahl, PR:33157)
- CORVON_V5 board added (@holydust, PR:33593)
- DAKEFPV boards add support for LSM6DSV and BMI270 IMUs (@engineer-dakefpv, PR:33984)
- FlywooF405S-AIO and -HD boards support SPL06 barometer (@mbuzdalov, PR:33779)
- KakuteH7-Wing boards support LSM6DSV IMU (@zebulon-86, PR:33761)
- ORBITH743v2 board added (@orbittechnologyx, PR:33582)
- Plane specific changes
- Q_P_JERK_NE/D renamed to Q_P_NE/D_JERK (@rmackay9, PR:33843)
- Quadplane: In transition only set TECS throttle min in auto throttle modes (@IamPete1, PR:33972)
- Copter specific changes
- Auto mode climbing Arc waypoint speed limits and velocity/acceleration fixed (@lthall, PR:33833)
- Auto mode fix to continue past RTL if rtl-final-descent non-zero (@rmackay9, PR:33797)
- Circle mode entry fixed when RC input present (@peterbarker, PR:33525)
- PSC_JERK_NE/D renamed to PSC_NE/D_JERK (@rmackay9, PR:33843)
- Simple mode fixed (@rmackay9, PR:33947)
- Library/Driver changes
- AC_WPNAV: Use of uninitialised values avoided in m/cm conversion code (@peterbarker, PR:33715)
- AP_Filesystem: Files without an End-Of-Line character get correctly read (@peterbarker, PR:33744)
- AP_FlashStorage: Fix incorrect value of
current_sectorduring init (@Juergen-Fahlbusch, PR:33640) - AP_Follow: Fix parameter ranges to include their defaults (@lthall, PR:33928)
- AP_GPS: Unicore baseline correction in vertical component of Unicore reported baseline (@lthall, PR:33730)
- AP_Mount: Fix AlexMos yaw angle scaling (@borischernov, PR:33785)
- AP_NavEKF: Log per-core source set in XKFS (@mykhailopylyp, PR:33904)
- AP_OSD: use Betaflight SYM_TOTAL_DISTANCE for DisplayPort distance icon (@coreyfarley, PR:33908)
- AP_RangeFinder: TFMiniPlus: Small delay added to improve read reliability (@IamPete1, PR:33709)
- ChibiOS: fix overdrive disabled on H7 boards clocked above 400MHz (@andyp1per, PR:33824)
- GCS_MAVLink: Correction in diagnostics printing (@peterbarker, PR:33800)
- IST8310 compass gets probed only if the driver is enabled (@peterbarker, PR:32696)
- Topotek gimbal network connection handling is corrected (@peterbarker, PR:33803)
- Tool changes
- build_options.py: Wrong dependecy for MAVLINK_SIGNING has been removed (@peterbarker, PR:33798)
Thanks to the developers and beta testers who contributed to this release!
