Toilet bowling even in Alt hold. I don't get it
this is a weird one.
From a day to another, no software change made, my heli started to don’t hold loiter anymore doing toilet bowling and even in alt hold is not stable.
Hardware changes made: removed play on heli head keeping everything smooth. Even moving the swashplate with blades attached feels super smooth.
Now I’m definitely not new to ardupilot, I have done usual compass calibration, in flight compass calibration and done mag fit. Issue persist. The feeling sometime in flight is that servos are not strong enough. It is a trex 450 FBL (no DFC) with hs-65mg on swash powered at 6v (heli is standard 3s Liion battery).
you can find here few logs from today (14-10-25) and compare to the old one in the same folder
HS-65MG’s are analog servos and may be part of the problem.
Digital servos are suggested for use with our helicopters here.
As stated, before it was totally fine.
I still don’t get it.
Log from earlier in the month shows desire roll and pitch more or less in line with actual roll and pitch. Log from yesterday as completely off, like there is a delay.
I connected bec to vbat2 to monitor bec voltage and it is quite consistent.
I’m a novice with tuning, but I’m wondering if raising ATC_ANG_PIT_P and ATC_AND_RLL_P some may help.
My 450L’s angle P for pitch and roll are 8 and 6.
3 may be a bit low.
If you had the same values before and didn’t have an issue, I’m not sure what it could be.
Your GPS and compass health look good.
Is your rotor system phase correct? Stiff rotor system may have less than 90° phase shift.
I’ve analyzed this problem in detail over the past years. To be short: Yes, stiff rotor systems do have less than 90° of phase shift. But only as long as the fuselage can’t follow at the desired rotational speed. I call this “static situation”. This is the case, when the fuselage is strapped down in a wind tunnel or when the control input is just there to counteract asymmetric forces like an asymmetric weight distribution. If it’s a normal control input which leads to a rotation of the fuselage (“dynamic situation”) every rotor has 90° of phase shift after the fuselage reached the final rotational speed. Regardless of its stiffness.
For our model helicopters the time it takes to reach this final speed is very, very short, so we always have 90° of phase shift. (As long as we’re not doing crazy things with asymmetric weights.) There are some helicopters which still need an adjustment but this is only due to mechanical reasons (mainly in rotor heads with three or more blades).
So unfortunately, phase shift is not the problem here.
@Lorenzo_Pessah I just compared the parameters of your very last flight and the last good flight (2025-09-27 18-06-24.bin). There are many parameters that changed, including AHRS_ORIENTATION. Was that an intentional change? Maybe you should just load the old parameter list to your board again and try a new flight.
Hi Felix,
Between end of September and 1st of October I upgraded the FC from a speedybee F4 to a similar Matek h743 sold by triumph autonomous system.
I have done several flight with the new FC (including 15m autotune if the tail in loiter mode) before the issue appears in the most recent flights.
I’m currently investigating hardware as at current stage I’m pointing my finger to a new hs65mg servo.
The very old once are super robust while the new one looks doggy as it vibrate a lot at startup, while being extremely underpower for the first seconds. I have replaced it with a completely different servos and pending a test flight as soon as I can.
Hi Lorenzo!
Hm, the hardware change makes spotting the cause of your problem more difficult here. Do you have the parameters of the last flight without toilet bowling? What changed since then? Or didn’t you change anything at all before the problem occurred? In this case, I think the most likely cause is indeed your servo issue. With a 120° swash plate a faulty servo could cause toilet bowling, I guess…
I just added few flights from yesterday. same folder linked above
I replaced the servo first and still same condition. I then started to play with pids (long log) and I got some questionable results when I reduced P for positioning which to be honest I never had to change in many many previous UAV plus before it was working ok.
last log I mechanically changed the phase but still nothig. Now if it is mechanically related, doing an head upgrade to a genuine align DFC might resolve. but I still thinking that i’m wasting my money. Other change I have done before is setup better the notch filter using notch one for the main head and notch 2 for tail and relative harmonics.
Did you entered a flight log of a successful flight after you changed your FC and before the problem occours first as @Felix asked for?
uploading now 2 more logs, one is 260mb while doing yaw tuning and it was working ok. they are from 09-10 and 04-10, both post FC swap
Apparently everything was due to too much D for pitch.
I had to reduce it 10X to get back to stable condition.
I then tried to due auto tune for roll but if failed.
In the same folder 2 flights from today.
