Is this problem caused by “Ground Mag Anomaly errors”?
In flight without payload, it flew without problems, with 3kg payload applied and toilet bowl phenomenon was observed.
Why is this?
This is a question about whether it is possible to upload the parameters of pixhawk4 FC to which px4 firmware is uploaded to Pixhawk4 FC where apm firmware is uploaded as it is.
You are mixing up your terms a bit - I think you are asking if you can use parameters from the PX4 firmware in Arducopter firmware. Definitely NOT, the maths and many things are entirely different.
And what Dave is suggesting is you disable the internal compass and retest the flight, the problem might be gone then.
If internal compass was the problem, it should have happened before the payload was applied.
no payload = no problem
3kg payload = yes probelm
Additionally I found the “ATC_ANG_PIT_P/R/Y” parameter.
Given the P-value for the angle, can this solve the toilet bowl enough?
First, as your advice, let’s fly without using an internal compass.
Another question here.
I am not already using Compass 3.
If i also turn off the internal compass, it’ll end up flying only with Compass 2, is this okay?
Higher current demand with payload could explain this.
Actually Mag 1 is your external compass.
COMPASS_DEV_ID,658945 (This is on the I2C Bus)
COMPASS_DEV_ID2,658953 (This is on the SPI Bus-Internal)
COMPASS_PRIO1_ID,658945
COMPASS_PRIO2_ID,658953
And there is no “APM Firmware”. There is Ardupilot Firmware and PX4 firmware and they don’t mix.
I confirmed that there are two compasses in the compass calibration item.
So far, one spi and one have been listed as i2c, but these hexa are both i2c.
I’m new to pixhawk4 so I’m not sure, but is this normal? I haven’t touched any parameters. Additionally, during the test yesterday, I remembered your words and disabled compass1, and the ekf in the hud window was still stuck in red. Are compass and mag two different concepts?
