Tips for a future VTOL project
Can you recommend a flight controller for VTOL UAV with autopilot.
The purpose of the project is long flight and mapping.
Using high resolution camera camera on board the drone.
Flight controller should have a port for this.
At the moment I am planning a 4+1 or 4+2 model (fusilage is not selected at the moment, I will look for a ready-made solution on the market in Europe (retail).
Integration with aid computer as I plan to automate the process of metadata transfer together with photos via LTE modem.
My previous experience is with a similar multirotor system on holybro x650 platform and using pixhawk 6x with connection to RPi as aid computer.
Should I look for a flight controller more specialized for VTOL systems for deeper integration or can/should I continue to use the Pixhawk 6x?
The RPi in past builds is used as a data transmitter that simply sends data to a powerful pc for further data manipulation, but
I am considering using Nvidia’s aid computer to simplify the system. So Flight controller should support simple Nvidia Jetson or Nano integration.
Also in the last build HRTK here3+ is used and if the alternative controller has even more simplified integration with HRTK I will be glad to hear a suggestion.
Thanks in advance for your advice.
