Tilted props - how to configure "level" for the flight controller? No
I’ve built a quadcopter with props tilted 25 degrees forward (adjustable), so that the deck flies level when the the props are pitched 25 degrees forward in cruise flight (the idea is lower drag in forward flight).
I’ve seen two ways to configure the flight controller:
  1. Tell the FC in parameters that it is mounted 25 degrees backwards (pitched up) - using “Custom 1”? And then…
Define Custom Angles:
  • Configure the roll, pitch, and yaw rotation offsets using:
    • CUST_ROT1_ROLL (Roll offset in degrees)
    • CUST_ROT1_PIT (Pitch offset in degrees)
    • CUST_ROT1_YAW (Yaw offset in degrees)
      1. Place the frame on a level surface (with the landing gear holding the deck (and flight controller) 25 degrees backward) and calibrate the accelerometer in that orientation, so that the FC sees that orientation as level.
      2. Both?
      Thanks…
Can i see a photo of this frame? BTW this is a great place to test in a sim program like Realflight.
You must configure the vehicle such that it shows level while the motors are pointing directly up, use custom board orientation for that, keep in mind that sensor offsets are in that frame.
OK, this is the change I made. AHRS_ORIENTATION to “Custom 1”, and “CUST_ROT1_PITCH” to 25, and I’ll do another accelerometer calibration.
