Tilt motors with vectored yaw
Hi, Looking for a parameter file for a tilt motor vectored yaw.
The VTOL is quad. Mostly need to understand motor servo programing.
I think if you step your way thru this you will have it:
Tilt Rotor Planes
Thanks Dave,
I think I have it working. Just wondering if there is a Params file I could compare with what i have now to check.
How did you find the yaw FF? Im having trouble figuring out the tilt rotor tunning. I wish Qautotune took care of that parameters.
you might need to manually tilt or cant the props to improve Yaw.
