Tilt Motor Quadplane Testing
(David Ardis) #1
Over he last few months months I have been building a quadplane - Tilt Motor version. I have done a successful flight in Qstabalize mode (https://youtu.be/dS3_w6jawXA), Has anyone advice on the best testing method for transition into forward flight.
While testing on the bench I cant get the motors to tilt forward. If i switch to manual should the motors not tilt forward by default as its basically a plane at this point.
David Ardis
(Pompe Cukor) #2
Go high, so that you have time to recover in-case anything goes wrong.
Also when doing your first test flight, it is recommend using QHOVER and FBWA only, and setting Q_TILT_RATE_DN and Q_TILT_RATE_UP quite low (say 20 to 30 degrees/second).
That was advice given to me by Tridge.
I was also under the impression, that switching to manual from VTOL mode would perform a immediate tilt forward and not wait for target air speed, as FBWA would. This both for emergency recovery (in-case transition fails and you want to save the plane with a dive in fixed-wing mode), but also how else you would you test forward tilt, apart from manually using servo tester.
Anyway there is a new section for VTOL now, I recommend you post there or ask a mod to move it. Also tilt is special, so might as well mention it in the title, not just quads. Quads are fine in arduplane, but from what I am seeing, tilt is till not too popular and needs experimenting.
(David Ardis) #3
A short video of the Motors Tilting on my quadplane showing the mechanism and motor mounts
Tilting Motors
(Pompe Cukor) #4
I am waiting for you to do transition :slight_smile:
Go go go. hahaha
(Rolf) #5
Don’t forget to set ARSPD_FBW_MIN value little bit above stallspeed and adjust Q_TILT_MAX angle so that the aircraft can safely reach ARSPD_MIN_VALUE.
Good Luck
Rolf
(David Ardis) #6
Rolf
Thanks for the tip don’t know min stall speed yet. Going to get a good bit of height hit the switch and see that happens. If I am not happy can always put it in manual and belly land. All going to be interesting
(Pompe Cukor) #7
Yes yes :slight_smile:
When? :wink:
(David Ardis) #8
Rolf
If you set ARSPD_FBW_MIN to for example 10m/s and Q_TILT_MAX to 45 and switch between Q_Stabalize and FBWA on the bench would i be right in thinking the motors should not tilt beyond 45 Degrees
In my case the go the whole way from 0 to 90 Degrees.
David Ardis
(Rolf) #9
That’s right on the workbench. In real flight the tiltservo waits at Q_TILT_MAX degrees to reach ARSPD_FBW_MIN m/s.
We use
Q_TILT_MAX|70
Q_TILT_RATE_DN|10| <----- important to tilt dn slowly
Q_TILT_RATE_UP|80|
Rolf
