Throttle servo not working
Hello my friends, I have a problem, which is the servo throttle of the gasoline engine is not responding. I have tried many attempts. What are the parameters that I should do, please?
The throttle servo by default only works when the plane is armed.
For rigging you can set the ICE_OPTIONS to allow the throttle while disarmed.
https://ardupilot.org/plane/docs/parameters.html#ice-options-ice-options
Thanks for the help, I followed your advice when I did Throttle while disarmed. It does the throttle but when I do armed the throttle stops and doesn’t respond… I don’t know, the situation has become upside down… Is there a solution?
There could be a few reasons. It could be that ICE_START_CHAN hasn’t gone high to trigger the ignition and start cycle. It could also be if you’re using RPM and the engine isn’t running then it’s holding the throttle at ICE_IDLE_PCT.
https://ardupilot.org/plane/docs/common-ice.html
