Throttle servo not working in servo outputs in mission planner
Hello, i am after some help with a problem on my Matek f405 vtol flight controller, i have downloaded the latest version of Arduplane 4.3.5. to the FC, and going through the calibration process i have hit a problem the throttle, Servo3 is set to 70 in parameters and the radio calibrated successfully, when i move to the next stage servo output the other 3 of the green bars move but the throttle bar does not ,Any help or pointers will greatfully received.Thanks Peter
I guess you have not armed the plane. Without arming the throttle output is not active, it stays at minimum.
