Hi everyone,
I am writing on behalf of the Lagari UAV Team. We are dealing with a throttle offset issue on our fixed-wing aircraft that is causing non-linear control.
The Main Problem: There is a significant mismatch between our physical stick input and what ArduPlane registers.
When we hold the Throttle Stick at exactly 50% (Center), Mission Planner shows ~57% throttle.
This offset exists across the whole range, meaning our “Zero” is not zero, and we hit 100% throttle before the stick reaches the top.
The Root Cause (Hardware Failure): We discovered that the physical Throttle Trim slider on our RadioLink AT9S Pro transmitter is mechanically broken.
The trim button appears to be stuck in a “High” position and does not respond to clicks.
Because of this, our Minimum PWM is stuck at ~1108us instead of the standard 1000us.
This explains why the midpoint is shifted high (57% instead of 50%).
Hardware Details:
Radio: RadioLink AT9S Pro (2.4GHz system).
Receiver: RadioLink R9DS.
My Question: Since I cannot physically repair the trim button right now, I need a software workaround in ArduPlane parameters.
If I manually change RC3_MIN and RC3_TRIM to 1110 (to match the “broken” floor of 1108), will ArduPlane automatically re-map the 0-100% range to fit within the remaining signal (1110us to 2000us)? Or do I need to adjust other parameters to fix this “50% = 57%” offset?
Thank you for your help.
