I am trying to configure Throttle Failsafe for the first time. Using the value of 950 for the THR_FS_VALUE it always triggers immediately regardless of the stick position. So I tried an experiment and changed it to 1200. Now FS is activated when the stick moves ABOVE 1200. Shouldn’t it only trigger when the throttle is BELOW this value?
I understand how it is supposed to work. I understand how to configure my Rx to go to 900 when the the Tx is off. I have done this with other FC’s.
I have redefined most of the 4 channels. Throttle is now ch 1 not ch 3. Some of the others are reversed, by clicking the check box, in the Mission Planner, but not Throttle.
Should I disassemble my 3x6 servo connector to reconfigure back to the default channel assignments? Will this solve the Bug?
Please Help!
