Firmware version is 4.1.5.
My unmanned helicopter is powered by a fuel engine. The engine’s speed is controlled by the internal governor. Before, I was flying in the same place, cruise control was good. Recently, I changed my flight to a different place, with an altitude change of 3,000 meters. I found that the parameters of the internal governor had to be readjusted to work properly. The parameters previously set are no longer applicable. I guess it’s due to the change in air density.
Is there a good way to solve this problem? Thus can be unmanned helicopter in different altitude can be better flight. I see that later firmware versions may have a parameter named “H_RSC_GOV_COMP”, can this parameter solve this problem?
Hope to get your help. Thanks!
