Immediately after takeoff, the altitude displayed on the OSD drops by approximately 30m; as the aircraft gains altitude, the displayed value rises accordingly. During landing, the OSD reading reaches 0m prematurely as the aircraft descends, and after landing, it shows -35m. While there are no issues with the flight behavior itself, it is quite unsettling. This phenomenon did not occur when I flew the same aircraft—running the same version—back around February of this year.
Have you changed any air venting in the fuselage? Blocked an outlet air vent or opened up something in the front? Looks like the pressure is increasing as the plane accelerates. It’s also saying 32 km/h on the ground so I’m assuming it’s still moving, or landing in the last picture.
No modifications have been made to the air vents on the airframe. The 32 km/h reading occurred while the airframe was sliding along the ground; once it came to a stop, the value dropped to near zero.
Look at your flight logs from February compared to this recent flight. Compare the GPS.Alt vs the BARO.Alt. See how they looked then vs now. It really looks like a pressure effect on the barometer with speed.
I’ve started to uncover the cause. Upon reviewing the GPS telemetry altitude (GAlt) data from this flight, I noticed that the value increased by about 40m before takeoff, and then dropped by approximately 36m immediately after takeoff. It seems likely that these anomalous fluctuations affected the altitude reading displayed on the right side of the OSD sidebar. Is the altitude value in the sidebar perhaps calculated by combining GPS telemetry and barometer (BARO) data? For reference, I checked the telemetry from February, and no such fluctuations in the GPS altitude were present then.
I had exactly the same experience, my altitude difference was about 20 meters. Enough to cause a crash on landing approach. Until today, I don’t have a root cause explanation for this.
