The GPS LED does not light up
I had an M10N GPS attached to my Pixhawk6X.
The GPS was recognized correctly, but the GPS LED wouldn’t light up.
When I attached the GPS to another Pixhawk6C mini, the LED lit up without any problems.
The GPS wasn’t the issue, and I couldn’t figure out the reason for the problem for a while.
Then I solved it from a different reason.
I had a PM02v3 power module attached to the Pixhawk6X,
but since it’s an analog type, it couldn’t be used with the Pixhawk6X.
I realized that only the digital PD02 would work, so I swapped it out.
After that, the LED started working.
It seems that when you try to use an analog PM with the 6X, the I2C settings get messed up.
It can be done, but not recommended.
The reason why the LED’s didn’t light up is most likely related to the missing signal that the PD02 will provide.
