tyoneda
(takuro yoneda)
February 25, 2022, 11:27am
#1
Hello, I’m building a small copter, but I can’t solve the vibration of the copter.
What are some common approaches to reducing copter vibration? Also, is there anything else I should do?
Current behavior
the copter vibrate in flight.
video of the copter in flight | google drive
Copter configuration
Firmware: Copter-4.0.7
Flight Controller: Matek H743 Mini
Battery: 4s 520mAh Li-Po
What I did
Regards
Alberto_Ds
(Alberto Ds)
February 25, 2022, 1:40pm
#3
did you use this?
https://ardupilot.org/copter/docs/setting-up-for-tuning.html#mission-planner-helper
in particular: Mission Planner Helper
You absolutely have to mount the FC with M3 rubber standoff.
Your google drive does not allow access
dkemxr
(Dave)
February 25, 2022, 3:03pm
#4
When you fix the Google drive access requirement (get rid of it) include a .bin flight log.
tyoneda
(takuro yoneda)
February 28, 2022, 6:56am
#5
Thank you
I’ll try to use Mission Planner Helper.
And the rubber standoff are already in use.
This is the flight log and video.
I’ve updated the permissions.
https://drive.google.com/drive/folders/1yTnbvTKL5ihDoRknV6QvPWQ47zGJzWQv?usp=sharing
dkemxr
(Dave)
February 28, 2022, 2:21pm
#6
You didn’t update the firmware as suggested or configure the Dynamic Notch Filter.
tyoneda
(takuro yoneda)
March 4, 2022, 2:30am
#7
MOT_PWM_TYPE was set to 0 (Normal).
I changed it to 6 (DShot600) and vibration was suppressed considerably.
There is still a bit of vibration, so I will adjust the notch filter and using autotune to improve it.
