Testing a Lion Pack - suggested changes?
I discovered that I have a 4-Cell 5000mAh pack that I made a while back - and I want to give it a try on my EDU-450 I built recently using the new CubePilot EDU-450 carrier board.
It weighs 150g less than the LiPo pack I used recently on this copter.
As I recall, the battery specs contribute to the thrust curve calculation. So I’m wondering if I should change any parameters for this test.
I re-ran the Initial Tune Parameters routine in Mission Planner and it had these suggestions:
lipo initial tune
Which, if any, of these parameters might be good to set for this Lion battery test?
Many Thanks!
You should only change the voltage related parameters
