Hello everyone,
I send you this message because I have some problems with the telemetry I use on my drone (FC : Matek H743-Wing V3). I am using Mission planner and I have configured the SERIAL with the correct parameter (protocol + Baud rate)
Both modules (ground and air) have a constant green LED and are on version 2.2. However, I can’t communicate with the flight controller (I get a timeout after 30 seconds). Has anyone had a similar problem? Thanks a lot!
Nicolas
Hi Yuri,
Already done but thanks ! I don’t really know what to do. Both radios are constant green + red lights blinking. I try to chang the baud rate for the USB connection but still not working.
Hi yury thanks you a lot for your help !
I check everything you say and i don’t think i made a mistake there. I can add that when I connect the ground station to my computer via USB, it crashes mission planner/my computer sometimes.
