Telemetry modules are not binding after configuring from mission planner
I am using telemetry ground and air modules with pixhawk 6x. It was binding fine initially. However, I configured the Mavlink option as raw data from mission planner SiK radio settings and they are not binding anymore. After that the air module’s red LED is always red and the ground module’s green LED is blinking. I tried to change the mavlink option to default settings of mavlink. However, when I click on load settings from mission planner it says that it is not able to connect for both the modules.
Can anyone please help bring them back to original state?
Thanks,
Sayan
Use mission planner to reset the parameters on the radios. Make sure both radios have all the same values.
Thanks Allister, I tried this. Even the reset to default button does not work as it is not able to connect to the modules.
