I am looking for a telemetry module. I believe the 915 MHz telemetry is in a frequency that is reserved in UK, and I will need one operating on the 433 MHz band. do you have any suggestions?
Good day, you can look for mrobotics telemetry module… work pretty well.
you can find it in 433mhz or 915.
If you are in the UK you could use 868mhz I use the RFD ones they seem very reliable
Thanks. I have been trying to connect navio2 +pi to mission planner and these are the issues:
I tried setting shownoise to False using :
set shownoise False
but still,
I have been having a similar issue :
Can you please help me with the same
pi@navio:~ $ mavproxy.py --master 127.0.0.1:14550
Connect 127.0.0.1:14550 source_system=255
Failed to load module: No module named adsb. Use ‘set moddebug 3’ in the MAVProxy console to enable traceback
Log Directory:
Telemetry log: mav.tlog
MAV> Waiting for heartbeat from 127.0.0.1:14550
GPIO_Sysfs: Unable to get value file descriptor for pin 4.
GPIO_Sysfs: Unable to write pin 16 value.
GPIO_Sysfs: Unable to read pin 16 value.
online system 1
STABILIZE> Mode STABILIZE
Exception in thread main_loop:
Traceback (most recent call last):
File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
self.run()
File “/usr/lib/python2.7/threading.py”, line 754, in run
self.__target(*self.__args, **self.__kwargs)
File “/home/pi/.local/bin/mavproxy.py”, line 783, in main_loop
master.wait_heartbeat()
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/mavutil.py”, line 383, in wait_heartbeat
return self.recv_match(type=‘HEARTBEAT’, blocking=blocking)
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/mavutil.py”, line 344, in recv_match
m = self.recv_msg()
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/mavutil.py”, line 922, in recv_msg
m = self.mav.parse_char(s)
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/dialects/v10/ardupilotmega.py”, line 9257, in parse_char
self.__callbacks(m)
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/dialects/v10/ardupilotmega.py”, line 9234, in __callbacks
self.callback(msg, *self.callback_args, **self.callback_kwargs)
File “/home/pi/.local/lib/python2.7/site-packages/MAVProxy/modules/mavproxy_link.py”, line 460, in master_callback
mavutil.mavlink.MAV_TYPE_DODECAROTOR]:
AttributeError: ‘module’ object has no attribute ‘MAV_TYPE_DODECAROTOR’
Thanks
