TBS Lucid H7 GPS Bad Health Issue 4.6.3
Hi There,
I have just setup a drone using the TBS Lucid H7 flightcontroller with the lastest 4.6.3 firmware. I wired up the gps to the serial 2 pads and the SCL1/SDA1 pads making sure the tx wire goes to the rx on the board and rx to the tx also to the board. I have made sure i have set the right baud rate of 112500 and the serial 2 is set to gps.
When i go out to the field to calibrate the compass and test, it captures up to 20 satellites and i look good to arm but i get a GPS1: BAD HEALTH warning preventing me to arm.
I checked my wiring once again and all correct and even replaced the gps but no luck. I then soldered to the SCL2 AND SDA2 Pads to see if that made a difference but i just get a GPS BAD HEALTH warning.
I saw there has been issues with the TBS Lucid H7 and getting the compass to work but wanted to ask on here what the fix would be.
I have had this build working with a different flight controller so compass interference isn’t an issue.
Thanks Harry
