Hello everyone,
I’m currently developing a VTOL platform, and I’ve recently started working on multicopters in parallel. I feel fairly comfortable with VTOLs now, but multicopters are still new to me, so I’m reading through the ArduPilot documentation and learning step by step. While studying, one question came up that I’d really appreciate some clarification on.
In the First Flight with Copter guide (Tips for New Pilots → First Flight), the manual says:
“If it lifts off smoothly, you may see a little yaw. That shouldn’t be more than about 30 degrees and will correct itself with more flying time. There should be no pronounced wobble (if there is, you may have an unbalanced prop or out-of-true motor).”
Link: Tips For New Pilots — Copter documentation.
I’ve noticed this behavior often when my teammates and I take off with a multicopter: right after liftoff, there is a small yaw movement. Until now, we assumed it was mainly due to wind or a general attitude instability. However, after reading the manual, it sounds like a small yaw rotation (within ~30 degrees) immediately after takeoff can actually be normal.
So I have a few questions:
Why does a multicopter tend to yaw slightly right after takeoff (within ~30 degrees)?
ChatGPT suggested this could be a natural transient: while the vehicle is still on the ground, friction between the landing gear and the surface prevents rotation, so some net torque “builds up.” Then, at the instant the vehicle breaks free of the ground, that stored/net torque is released and the vehicle briefly yaws.
Is this explanation accurate in real multicopter setups? Or is the yaw more related to software/control behavior (for example, a control loop transient while stabilizing immediately after liftoff)? -
The manual implies that this small yaw improves “with more flying time.” What exactly does that mean?
Does it mean the controller actually adapts over time (for example through learning, trimming, or other automatic compensation), so repeated flights gradually reduce the takeoff yaw?
Or does it simply mean that once the vehicle is airborne and stabilized for a few seconds, the yaw naturally settles and becomes less noticeable? -
Someone I know mentioned there is a way to disable this yaw behavior. If I disable it, what are the trade-offs?
Could disabling it reduce safety margins or hide an underlying issue (like motor/prop imbalance, ESC response mismatch, etc.) that I should solve mechanically instead?
After going back and forth with ChatGPT, I realized how valuable real-world experience and practical advice from experienced pilots and developers can be. Sorry for the long list of questions—but if you have any guidance, personal experience, or references to additional documentation that I may have missed, I’d truly appreciate it.
Thank you!
