I am trying to “TAKEOFF” using Mission Planner but that doesn’t work. I have set my takeoff altitude to 1.5m. The command called “TakefOff (2m)” works though. But the Takeoff command issued by QGC works. How can I fix this?
IIRC QGC overrides the throttle stick instead of sending takeoff command.
Okay… So how to make it work via MP to takeoff to the TKOFF_ALT altitude instead of taking off to 2m everytime?
Can you share a screenshot of the mission planner button that works like you expect?
Seems like the “TakeOff” command under the “Set Home Here” works and it allows you to set the altitude too. The “TAKEOFF” command shown in the above image does not
