Takeoff Failed with Optitrack for Non-GPS Navigation
I am trying to fly my Ardupilot drone with Optitrack indoors. I followed the instructions here: Optitrack for Non-GPS Navigation — Copter documentation. The only configuration I could not follow was the EK2_ENABLE to 0 because EK2 does not show up on my mission planner.
I am successfully getting the initial position from Optitrack and I change the mode to ALT_HOLD and arm the throttle successfully but when I try takeoff 3, I either get a Got COMMAND_ACK: NAV_TAKEOFF: FAILED or I don’t get this output but either way my drone never takes off. I don’t think it’s a hardware issue because I can takeoff with my RC controller.
I have also tried taking off in STABILIZE, GUIDED_NOGPS, AUTO, and GUIDED mode but the same issue persists. I read somewhere that I could only take off in GUIDED mode, although this contradicts the instructions for flying indoors; I tried it but I failed the pre-arm check because AHRS is waiting for home. I would appreciate any help to resolve this problem.
Here is the log file: 2 12-31-1979 5-00-00 PM.bin - Google Drive
Thank you
you need to set the home position.
Please see this topic.
How are you sending the Takeoff command?
Tristan
I tried using the setorigin 0 0 0 before arming and taking off but I am still unable to get lift off.
I am sending the takeoff command through the command prompt that pops up when I run MAVProxy.
@fkorsah what command are you typing in the mavproxy window?
You may want to try adding a valid lat and log and see if that improves.
I have also not gotten this to work so I appreciate any other users input.
Thanks, Tristan
I set the optitrack code as directed in the documentation, then set the origin. Lastly, I enter in optitrack start to get my position. (I have tried the start before setting the origin as well.) I then enter arm throttle then takeoff 3. I also used a valid long and lat but I didn’t change anything. When I arm the motors spin but takeoff is not successful.
Hi @fkorsah,
Similar to what @Tristan_Redish suggests, setting the origin is required (setting home is NOT required). It’s best to set origin to a valid location (e.g. where the vehicle actually is) instead of 0,0,0.
To take-off autonomously the vehicle should be in Guided mode.
Re the contradictions in the wiki regarding indoor flight, I suspect it is the Indoor Flying Guidelines page that is causing confusion. I’ll try to clarify this but what your setup requires is the Non-GPS wiki pages.
@fkorsah,
We’ve updated the indoor flying guidelines wiki page now so that future users won’t be confused by it.
Hi @rmackay9 ,
Thanks for the info. I went through the wikis and made some changes to my setup. I added an extra marker so I have 4 markers on my drone. According to Indoor Flying Guidelines — Copter documentation, I set up GPS1TYPE, FS_THR_ENABLE and FENCE_ENABLE as instructed but BATT_FS_LOW_ACT did not show up on my Mission planner.
According to Non-GPS Navigation — Copter documentation, I tried to set EKF home origin but I got a “No SRTM data for this area”, but I was not too worried about it since I do the setorigin in MAVProxy. Finally for the optitrack specific setup, everything is configured with the exception of EK2_ENABLE as posted originally.
After these changes, I ran MAVProxy, this time I set the origin with the accurate long and lat, I also used the altitude from sea level. I was able to takeoff using a takeoff 1 command but the drone kept rising. The space from my floor to my celing is ~2.5m so I expected the drone to stop after getting to 1m but I didn’t. I also tried setting the origin with a 0m altitude but go the same result.
Am I missing something to stop and hold position when takeoff altitude is reached? PS. I am using guided mode as suggested.
Hi @fkorsah,
Sounds like you’re making progress.
Just to clarify a few things:
I suspect the issue with the vehicle climbing too high is that the AHRS home was set and the takeoff command is always relative to home.
