T-Motor Velox F7 Flight Controller with ArduPilot Firmware
Hi everyone,
I’m currently using the T-Motor VELOX F7 flight controller, but I noticed that there is no specific ArduPilot firmware available for this FC.
I want to confirm whether it is possible to safely use any other compatible firmware target for this board so that I can run ArduPilot, as I am interested in experimenting with it but don’t currently have the budget to buy another flight controller.
If anyone has experience using ArduPilot on the Velox F7 or knows a compatible firmware target, please let me know. Any guidance would be really helpful.
Thanks in advance!
If you don’t see it in this list (latest Dev) then it doesn’t exist and you are out of luck. You can’t just use another firmware target unless it direct copy/rebrand of another Flight Controller.
Arducopter Latest
Actually you are out of luck no matter what as the F722 processor is not supported by Ardupilot.
Thanks for the clarification, I just wanted to ask if there is any possibility of future support, or if there are any unofficial or community-built firmware options that could work with the T-Motor Velox F7.
No and no. iNav, Betaflight…
