T-Motor F55A Pro III AM32 ESC current telemetry reports 11A with RPM = 0
I am using a T-Motor F55A Pro III 4-in-1 ESC running AM32 firmware with ArduPilot 4.6.3 on a CUAV X7+.
I noticed a possible issue with ESC current telemetry.
Observations:
  • ESC voltage telemetry appears correct.
  • ESC RPM telemetry appears correct.
  • BAT.Curr from the battery monitor behaves normally during flight.
  • ESC1.Curr to ESC4.Curr continuously report approximately 11.7-12.0A.
The strange part is that after arming, all motors are stopped and ESC RPM remains 0, but ESC current is already reported as approximately 11A on all four ESCs.
During flight, the ESC current values change very little, while BAT.Curr varies normally between approximately 14A and 25A.
Because RPM = 0 while ESC current is approximately 11A, the telemetry does not appear to represent actual motor current.
Hardware:
  • CUAV X7+
  • ArduCopter 4.6.3
  • T-Motor F55A Pro III 4-in-1 ESC
  • AM32 firmware
  • T-Motor MN3110 700KV motors
Has anyone seen this issue?
Could this be:
  • an AM32 current sensor calibration issue?
  • a firmware issue?
  • or a telemetry scaling/configuration problem?
Thank you.
Attached screenshot shows BAT.Curr (red) varying normally while ESC currents remain almost constant.
I also observed approximately 11A ESC current immediately after arming while all motors were stopped and ESC RPM remained 0.
Everyone will see this. Use the analog current pin on the ESC into the Flight Controller for current. Individual ESC Current is generally not in the telemetry stream of 4-in-1 ESC’s.
Thank you for the clarification and advice. I understand now that the individual ESC current from a 4-in-1 ESC is generally not included in the telemetry stream, so what I am seeing is expected.
I will try using the ESC’s analog current output connected to the flight controller for current measurement.
Thank you for your help.
Is it common for 4-in-1 ESCs to be unable to provide individual motor current readings through telemetry?
I am using a T-MOTOR F55A PRO III with AM32 firmware v2.17 and a CUAV X7+ running ArduCopter 4.6.3. RPM telemetry is working, but I am trying to determine whether individual ESC current readings are supported or whether only the total current is available.
Is this a general limitation of 4-in-1 ESCs, or does it depend on the specific ESC and its telemetry implementation?
Most 4-in-1’s have one shunt resistor on the board for total current not one for each ESC section. On units that do have a shunt resistor for each section, very rare but I have one, it will be in the telemetry stream. At least on the one I have it is.
I have a T-MOTOR F55A PRO III 4-in-1 ESC running AM32 v2.17 with CUAV X7+ and ArduCopter 4.6.3.
I recently replaced my previous BlueJay ESC with this AM32 ESC. RPM telemetry is available for all four motors.
The attached graph shows ESC1–ESC4 current telemetry from a flight log. The reported values are approximately 11.7–12.0 A for each ESC.
My question is: does this indicate that the ESC is reporting individual motor currents, or could the same total-current measurement from a shared shunt resistor be reported by each ESC?
I would also like to understand whether the F55A PRO III has individual current-sensing shunts for each ESC section, or only a common shunt for total current.
I would say that data is meaningless and that ESC does not have 4 shunt resistors. But you can’t tell from the heat sink.
One that does looks like this:
Keep working it, perhaps you will get a different answer.
Here is a Pro II without the heatsink. I had one of these. Note the one shunt resistor. It doesn’t mean a Pro III doesn’t have 4 but I doubt it.
Thank you, Dave. That helps a lot. The ESC1-4 current stayed at about 11.7-12.0 A over the whole flight, even though ESC RPM varied from 0 to about 6700 and BAT.Curr varied from near 0 to 25 A. So I agree the per-ESC current values are not real measurements. Thanks again for your time.
