T-Motor AT115A ESC: Programming via Programmer or BLHeli – Any Experience?
Hi everyone,
I’m working on a project that uses the T-Motor AT115A ESC, and I’m currently trying to figure out how to properly program it. Unfortunately, I couldn’t find any detailed documentation or user manual for programming this ESC on the official T-Motor website.
At the moment, I’m testing it using a servo tester, which works fine for basic operation. However, I’d like more control over settings like braking mode, startup power, timing, etc.
:red_question_mark: Has anyone here had experience programming the AT115A via a dedicated programmer?
  • Is it compatible with BLHeli, BLHeli_32, or any other programming tools?
  • What kind of programmer or adapter would be needed?
  • Is there a way to read or flash the firmware?
Any advice, personal experience, or links to documentation would be greatly appreciated!
Thanks in advance!
AFAIK T-Motor doesn’t use any version of BLHeli, IIRC some of their product lines support telemetry and maybe configuration using dedicated hardware.
Yea there is. The old way of programming with the transmitter.
ESC manual
