I am using GSF for Loiter, Now Alt_hold mode not showing any problem but in loiter after activating the GSF it is automatically doing some to and fro motion in roll or pitch axis without giving any stick command. i have been seen this issue with 4.7.1, 4.6.3 earlier I used with same drone no such things have been observed. I am attaching the log file also.
Hi Rohit, I’ve started examining the DataFlash log. In the segment reviewed so far, GPS reports 15–17 satellites and HDOP around 0.60–0.66, while the attitude tracking differences are relatively small. I haven’t yet found evidence proving GSF is the cause. Could you share the approximate log timestamp when the forward/backward movement begins? That will help narrow down the relevant EKF and position-control data.
