Ok, I start with Chris’s advice. Shaft is level on the gear, so that’s a good start. I take out my digital pitch gauge aaand…the offset will vary depending on rotation of the blades. Not -3 to 3, but 0.6-3. There’s clearly still work to be done on the mechanical side.
However, knowing that rain is forecast, I’m also keen on getting out to try Bills advice. It’s not ideal, as it’s gusty and swirly.
I start by lowering the FILT to 4 and immediately it seems a little more responsive. I gently push up the P, but it not showing huge improvements and short attempts to loiter are much much worse. I then increase the ILMI to 0.1, which makes taking off a little bit more of an adventure , but it allows me to push up the P further and further to 0.095/0.09 and it’s probably the best it’s been in stabilize. Again, wind conditions make it hard to judge.
Loiter it still pretty bad, but I realize that I was messing around with the loiter parameters yesterday and reset them and it improves a fair bit and the log shows it’s still chasing it’s own tail a lot, but the roll/pitch vs des.roll/pitch are much improved. Then my ground station battery started dying (I need a new one!) and I had to call it. At least it felt like a step in the right direction!
I’ll strip the head down and check that everything is straight, etc and then retry Chris’ method. Currently I have a 10 degree offset on mission planner, when the heli level
Video of last flight.
2017-04-23 13-06-23.log.param (10.8 KB)
2017-04-23 13-06-23.bin (2.4 MB)
